Old Nov 29, 2009 | 11:16 AM
  #49 (permalink)
mrphotoman's Avatar
mrphotoman
Default Re: Planned modifications on my SRT6
Originally Posted by cruzinquick
It was when I sent back my mani's to have them coated, and installed the stock mani's back on. It was only an 11.99 and not better than my best of 11.97 which is now 11.96 in AZ. What you dismiss with the mani's because of the cost is the fact they lower boost and still outperform the stock mani's. Less boost means my motor is not running as hard as others without the mani's. Test it yourself and come back with the results.
I know your sore that I don't acknowledge your 11 sec pass because it was on spray.
Good job on driving, that deserves an atta boy!! There it is put it to rest or run an 11 without spray. Check the meth discussion on mb. I do believe it may cause some corrosion, but we won't know until someone like you tries it for an extended period of time. I give you credit for risking your motor for the forum. Another atta boy!!
On AFR's are you serious? That's not even a discussion. Couldn't I have been anymore sarcastic for you to get it?
The only reason I encourage members to use DA readings when running at the track is so they can compare to other members with similiar mods under different conditions. At least they know there is not something wrong with their car. I know you disagree anything I say about DA, but that's ok just like we have our difference of opinion on the use of meth. Oh well.
Distant -- you will be there and I'll be happy when you do. It gives me hope to search for the same conditions and add an 11.7 slip to the mix. 11.6's that's a whole 2 tenths and it's hard enough to pick up a tenth, so don't think that will ever happen for me. I'm ok with it. I'm almost done with the six and will start saving for an SL55 a couple of yrs down the road. I'm sure Rob will have some goodies ready by then.
I'm done with this one, at least for a good week. LOL
LMAO! I can not believe how arrogant you are! I know you can not help it that you are slow, no need to be jealous.
Also, do some reading on "spray" or what normal people call alcohol injection, it is not a power adder.
Regardless, lets see this elusive timeslip that you never posted or told anyone about or added to your sig that you are so particular about updating with what you ran with what mods. I am sure it was ran on a 100degree day at 9000ft altitude and 100% humidity for a DA of 100,000ft lmao.
Also, you fibbed a little on your dragtimes 11 second da. Yet another lie you have posted on here to try and make yourself look like a big boy.
I can only imagine how insecure you must be to feel the need to be so arrogant online. Poor guy.
I think you need to change your name to cruizinslow, it suits you better.
