Originally Posted by tashgu
Hi, well done for appearance mods!
question on Koni adjustable shocks: why are they called adjustable, i.e. do they make the ride softer/harder depending on driver's preference? If yes, how easy is to make the adjustment. Thanks!
Tashgu
The Koni shocks are adjustable for compression dampening. There is a **** tool you put on the top of the shock tower and turn to soften or stiffen the ride. All you have to do is open the hood for the fronts. The rears are accessed by removing the interior panels in the trunk which is very easy. You pop out a few plastic buttons. You can cut a hole in the panels to access the top of the shocks. I didn't want to cut holes in the panels since they are so easy to remove. When on full hard, the car handles like a race car. When on full soft, it rides like a Caddy. It's set up about 1 1/2 turns from full soft.
Thanks,
Dan
