Re: Problems with the Crossfire by your build number
Where can I find a true list of recalls on the XF? Also, my disply on the stereo is VERY dim... is there a way to fix it or should I just replace it with an aftermarket headunit? Window switches appear to be backwards. I believe pushing up should make them go up not down... which is right which is wrong? German made so, maybe it's just the way Germans expect things to move when you push them that is...
Also, I noticed on the headlight switch, I can pull the switch out two clicks. One for the foglights, but the second one does nothing. My passenger seat is supposedly an 8-way seat, but it does not go up and down. Making a list of defects (previous owner probably never found) and will take it to the shop to have repaired when the key comes in from Germany next month.
