Old Dec 4, 2009 | 02:44 PM
onehundred80
Default Re: Throttle Body Modification
Originally Posted by rcompart
Just an FYI, it's not an easy process to take these throttle bodies apart. They are meant to go together once and then not be serviced. I've got the first one I tore apart in a box in pieces because I discovered upon disassembly that the gear is an injection molded plastic part that is molded around the shaft and you don't want to mess that up.
I counted on removing the throttle plate and pulling the shaft out. That looks feasible in all the pictures I have seen, maybe not though.
