Re: Air Conditioning Problem
Thank you for the advise. So far this falls into a do it myself project. My garage is also at 15f right now, so it will have to wait for a day at least above freezing, which could be awhile. What is the difference between R112 and R134? Can I get partial pressure or is it all or nothing. If you can get some pressure how do you bleed it to refill. I will follow up as it seems like you guys know what I can do if it's not a pressure issue, or let you know if a refill does it. Also, I read in the manual that the AC will not blow cold below 40 degrees. If so, how do I test it?
