Old Dec 6, 2009 | 11:55 PM
tighed1's Avatar
tighed1
Default Re: Throttle Body Modification
Originally Posted by BlueStorm
a smarter idea would be to start with the big v8 TB, bore that out, might need to destroy one to find max ID for bore. and then change the closed throttle valve angle for about 3-5 degrees more agressive, that should help remove any throttle lag.
let me know if you need help on how to change the angle, you will need to buy some decent ID calipers.
But that would be like "spraying"!
I did get to the port matching. There was a lot of overlap that got taken out. It has to help.
