Originally Posted by shubi.s
Thanks, I had the oil changed for the first time this summer (only 5,000 miles when that was done,) and a few weeks after that I had a rough idle/drive a couple of times coupled with a check engine light, which would go away with a restart. Could there be a link between a valve cover leak and that?
I'm not sure about the check engine. You should check if the belt is covered with oil. If it's slipping it could be causing some of the problems.
