Old Dec 9, 2009 | 08:18 PM
  #905 (permalink)
rcompart's Avatar
rcompart
Default Re: V8 Crossfire Conversion Diary
Originally Posted by kanzus
At the pdf "E 55 AMG Komp 113.990 sheet 2.pdf" you can see that Y2/1 IS SUPERCHARGER MAGNETIC CLUTCH:
- 0.75MM BKPK (black pink) wired to ecu pin 1.1
- 0.75mm RDGN (red green) is wired to Z7/36 ---> what does it mean Z7/36 ?? is it a relay, or gnd point or fuse??? any idea?
Karim,
I'd need to see the other PDFs because there is a good chance that Z7/36 is actually a fused +12vdc supply somewhere in the engine harness or in the engine compartment. It would make sense because the relay would close to ground in the RCM to engage the clutch. If you want, you can give me a call or email me. My email is rudy@acceleratedindustries.com and my phone number is 952-681-1000.
Thanks
