Old Dec 11, 2009 | 03:01 AM
corfire's Avatar
corfire
Default Re: My H7 bulb headlight saga
Originally Posted by apkano
I have no idea how you people remove the spring/retaining wire, but I'm reasonably sure most of you are doing it wrong. It simply pushes in and to the side from the bottom to unhook it, then it just pivot's up and out of the way.
I've only replaced mine once, but found it easier to just remove the clip because it seemed to be in the way a bit when it was just unclipped on one side and pushed to the other side. It removes easy with a needle nose pliers by compressing the clip a bit. Yes, you do run the risk of losing it. After seeing how it all goes together the first time, I will probably just swing it to the side as you do. Either way, it's not really all that hard!
