Originally Posted by blaispi
Simple fix to all the H-7 replacement problems. So here it is: Take a chopstick, break in half, take the wide end of the stick cut a notch "V" in it. Remove the cover, remove the wire connector to the bulb. Now take the chopstick "V" and insert on the metal wire clip that holds the bulb in place. Remove the bulb and reverse. Done 10 Min job.
