Thread: is this normal
Old Dec 15, 2009 | 01:59 PM
robby363's Avatar
robby363
Default Re: is this normal
Originally Posted by SRTGuy
The first pump was probably good.
My money is the IC pump FUSE is blown. Same symptoms as broken IC pump. Check it out. I put one 5amps higher in when I switched the the johnson.
I had the johnson pump and it worked great for about 7 month's. Then it started blowing fuses so I switched the 10 amp with a 15 amp fuse. The good news was it didn't blow the fuse anymore but the pump didn't work after that either. I have replaced it with the ford lightning pump and has been working great so far.
