I got my LED's plate lights installed and turned them on..... no light...
Pull LED and check voltage, yep 13V....hmmmm..... Oh yeah, this is NOT a light bulb. Turn LED end for end and plug back in.... dang..those are bright!
Howard, I was trying to figure out why your hatch looked different than mine. Then I checked your signature and see you have a roadster. I was able to mount my resisters on the back side of the frame. Drilled a .136" hole(6-32) in the frame, tapped the resister mounting hole for 6-32 screw and then used blue loctite on the screw. I think I will add some heat shield to the outside surface of the hatch above the resistor. Those are even hotter than I thought they would be. There is plenty of room around the resistor where I have it mounted, but I would like some insurance on the outer surface for my paint.
I'll post pics when they fix the gallery.
