Thread: is this normal
Old Dec 15, 2009 | 09:48 PM
32krazy!'s Avatar
32krazy!
Default Re: is this normal
Originally Posted by mrphotoman
I think the best pump is the "ford lightning" pump on ebay. It is a direct fit, flows more than enough and best of all is under $100 shipped!
I still feel it is the way to go, why pay more or have more install headaches than you have to? I am all for using what works best for the least $ and least effort
I would hardly call a pump that requires "custom install from the electrics to the hoses to the mounts" the best pump when it does not give you any more power, only more headaches and less $ in your pocket.
ford lightning pump needs wiring. you also need to remove the top and reuse the oem top as the ford lines are smaller. and for the 100$ you still have a bosch pump that WILL fail at some point.
yes the meziere is more work. but not that much . it outflows and will outlast any pump being used today.
with the amount of people using remote tanks and larger systems this pump will handle all the biggest flow demands.
cheaper isnt always better
