Originally Posted by 32krazy!
ford lightning pump needs wiring. you also need to remove the top and reuse the oem top as the ford lines are smaller. and for the 100$ you still have a bosch pump that WILL fail at some point.
yes the meziere is more work. but not that much . it outflows and will outlast any pump being used today.
with the amount of people using remote tanks and larger systems this pump will handle all the biggest flow demands.
cheaper isnt always better
post up your data proving that it will do all the things you say.
you take out a few screws, swap tops then splice in the ford pump and your done in about 4 or 5 minutes. the pump will fail? any pump will fail, just like any car will eventually fail like any other mechanical thing.
mine is working great and that extra money sure was nice to keep too.
