Thread: is this normal
Old Dec 15, 2009 | 10:18 PM
mrphotoman's Avatar
mrphotoman
Default Re: is this normal
Originally Posted by 32krazy!
heres a breakdown of the meziere pump.
Meziere Enterprises
the screws on the bosch pump strip very easily. your welcome to use any pump you choose. keep the extra cash you will need it for another pump. as for any pump failing the pump your buying is the very cause of the biggest complaint on this forum. just what i would buy to replace a known problem, the same pump again!
for me i have the cm30 and it works great. when i add my 3 gal tank i will add the meziere. just my 1/2 cents worth.
the reason the stock pumps fail is because the vast majority of these cars sat on lots for long periods of time without being used.
my pump is still going strong thank you.
everyone, just buy what you want.
some people like to spend way more money with no better results. some people like to spend less money for same results. it is up to you
