Door Handle Installation
Dec 17, 2009 | 07:02 PM
permalink
BrianBrave
<--- Huge Horsepower
Apr 2007
3,217
So Cal
- Forum Super Sponsor -
Re: Door Handle Installation
Did you drop the allen head screw into the door (the one that you removed by pulling back the weather strip)?
Take your time. Set the black gasket in place (it has two small hooks to hold on to the door) then slide the pull handle in and slide it forward into the catch on the door.
Then use your finger or a screwdriver to hook the flat metal latch (in the door) onto back of the handle. Eaiser if you have the door panel off, but can be done with it on. Once this is done it will stay in place (if you dont slide it back).
Fit the keyset into the door (you'll see where it goes) then screw the allen head bolt into it from behind the weather strip (long allen wrench needed).
Don't ask me how I know... Good Luck...
BrianBrave
View Public Profile
Send a private message to BrianBrave
Find all posts by BrianBrave
