Old Dec 18, 2009 | 01:59 PM
amx1397
Default Re: Companies who make after market rims?
no that is the bolt pattern you want 5 on 112 (bolt pattern) ET20 that is the offset of factory wheels on the rear,,factory fronts are 37, if you found some rims with a 2" lip(on the front edge of the rim) like the ones below, and it has 5 112 with offset (ET) of 40 to 47 it would also work,, because of the lip,,, if there is no lip your offset needs to be close to 20. 20 to 27 would work, look at you factory wheels the REAR ones there is no lip and the offset is 20 ,,,look at these below they are 17's 1.5 lip with 47 offset. jim
