Old Feb 21, 2005 | 10:07 PM
Hobbymanbill's Avatar
Hobbymanbill
Default Re: Simple Intake Mod / V-8 Airbox !
Originally Posted by XethW
I'm glad you put such an emphasis on being correct, hobbyman I too think it's important to be correct. One should always do their research before claiming to know something, yes? I feel that way, and I'm glad you do too. Accuracy is SOOO important in life.
If you go to Ford's website, you can read about how Ford's V-Mod program works - The V-mod engine block (and I am only talking about the block) is not casted in a V-6 configuration - rather, they are casted in banks of two cylinders - a V-twin more or less. The cylinder banks are then powder cintered (I may be spelling that wrong, but considering you will be rude one way or the other, I'm not going to take the time to look the spelling up) together to make a V-6 or V-8 (or feasibly even a V-4). What you are speaking of is not an aspect of Ford's Engine Mod program - you are simply talking about increasing the displacement within a single V-8 block - what most of us would call 'boring and stroking'. The entire premise of the V-mod engine program was to create an engine block that could be expanded from 6 to 8 to 10 cylinders while using the same heads, cranks, etc in order to cut costs. If you remember, the first concept version of the Ford GT did not use a supercharged 4.6V8 - it used a 6.0 V10 from the V-mod program, which was going to be Ford's flagship engine that would go in all of their cars using 6 cylinders and up. I do not claim to know as much about cars as everyone, or even most people on this forum - however, I do read before opening my mouth and spouting off to everyone how dumb everyone else is, in the hope I don't appear to be an ignorant moron (I am aware you may think of me as an ignorant moron, but I take that as a form of compliment - much like Galileo must have felt when the Church called him a childish imbecile for declaring the earth revolved around the sun).
Well partner you and the other children should learn a little more before you spout off. Everything you just said is BS. The ford mod motor was always designed as a V8. It was designed to be an overhead valve (both 2, 3 &4 valve) engine that by using different cranks,Sleeves, and heads could be configured in different displacements (not different numbers of cylinders)> maybe you should do a little more reading!!!!!!!!!!!!
