Re: Installed new Momo shift **** today
No Momo, used AutoZono:
Installed 2 shifter ***** from AutoZone, one on Snow White Alabaster Limited Cpe $19.95
and one on Blue Boy Aero Blue SRT6 cpe $14.95.
Both installed easily. I did drill the **** about 1/2" deeper for aesthetics.
Ease of removal....Be sure lower collar is completely unscrewed from ****. Use a large pair of water pump (Slip Joint) Pliers and put the handles around the shaft between the collar and the ****. Close handles enough to move up and down without scratching the shift rod, and using an upward "tapping" motion with both hands on the pliers, gently tap the **** up. When it's loose, pull it up by hand. Be sure to use the correct size replacement collar (comes with 3) position the **** and tighten the 3 allen screws.
Reason: include pictures
