Old Dec 23, 2009 | 11:37 AM
chevyboyac's Avatar
chevyboyac
Default Re: Changing the Fuel Filter - 2004 Coupe
I could scan the pages from the manual and show u the steps but this site is actin weird with addin pics....but search you might be able to find the actual manual on here if you find a 05-07 manual its purdy much the same. The filter is in front of the pass. rear tire above a plastic cover take the 4 screws off and you will see it next to the fuel pump. Its really easy to change, just make sure to pull the fuel pump fuse out and start the car that will get rid of the pressure thats in the line and you won't leak fuel everywhere.
