Old Dec 23, 2009 | 07:16 PM
onehundred80
Default Re: Window fitment problem
I have a noise coming from the passenger side window because the window does not keep close to the seal on its travel to the top.
The fix is to remove the door liner and adjust the window mounting mechanism, to make the glass have more lean in at the top.
This is not too big a deal, go to the shop manual and the procedure is laid out. If you read the TSB's there are one or two on this issue and one of them gives dimensions to use.
