Old Dec 26, 2009 | 02:46 PM
onehundred80
Default Re: Battery or something else?
Originally Posted by MikeR
If NAPA cant tell you if it is good or bad, I would worry about the test equipment or the tester. You could have one or more bad cells and it is just no good. Stuff happens. At a year old you should get some help on the replacement cost.
To test a battery it has to be charged up, if it does not charge properly then it is bad, if it takes a charge but fails the load test it is bad.
You cannot test a flat battery.
