Old Dec 28, 2009 | 06:23 PM
tighed1's Avatar
tighed1
Default Re: Transmission Problem
This isn't a hard DIY procedure at all. VERY messy but not hard.
Be aware though that when inserting the black sleeve into the transmission that it should go in without force. The piece that the sleeve slips into is a plastic connector on top of the valve body and is held in place by two plastic tabs, one on the left, one on the right of the connector (inside the transmission).
Should you push too hard you might dislodge one of the pins and cause an electrical problem that you don't want! (Don't ask). If you finish and the car stays in limp mode, you messed it up.
Pictures and explanation one of these days.
