Thread: Wind Restrictor
Old Dec 28, 2009 | 08:00 PM
  #88 (permalink)
WindRestrictor's Avatar
WindRestrictor
Former Vendor
Default Re: Wind Restrictor
YouTube - Red LED Windrestrictor
There's a video about it. Our latest feature is the 9V addition which enables you to keep it illuminated when the car is off.
Brake Light Module Option This option is a very nice option. It's a module that you can install in your console "waterfall compartment" or in your trunk on your rear panel. It has 2 ***** on it. After installed the first **** will control the Running light intensity to your product. You can use this **** as a dimmer **** to adjust the illumination while you are driving with your running lights on or headlights on. The other **** controls the brake light intensity to the product. You can adjust this **** if you want the product to illuminate when you apply pressure to your brakes.
With this option you can set the product for the following:
  • Restrictor can be set to come on only with the head lights,
  • Restrictor can be set to come on only with the brake lights,
  • Restrictor can be set to produce a certain illumination while driving (like a mid-intensity) and then produce a brighter glow when you apply pressure to your brakes when you stop. Kind of like a 3rd brake light option.
  • Also, this module will allow you to turn off product all together if you want. If you did not want it on for some reason, then you could turn both ***** down and then you'll just have the laser etching.
Finally, our new battery packs come with a built in battery pack (9V). So just flip the toggle switch and you can have the restrictor illuminate at the intensity you desire even when the car is off. (good for car shows). So this is a wonderful option that allows you to tap into your running lights and your brake lights simultaneously, and adjust each independently.
