Originally Posted by ron maness
here is the question rebuilding damaged crossfire hit in front lights were damaged the ? there are 4 mounting screws and on the bottom of light assy are 2 hex nuts adjustable do they sit on any bumpers on the light cavity where the light assy goes?
Are you talking about the large ones for adjusting the beam hight etc? (the bottom screws go right into them) There are no bumpers that I can remember but they kind of slide into a specific spot. It's hard to explain without seeing it. If you have the tire off and the lining and such removed it is easy to see how things go together from the bottom. If your trying to work through the hole in the plastic it is almost worth it just to remove all the stuff and get a good look. Once you see how it all works you will be able to work through that little hole a lot easier next time. (was for me anyway)
