Originally Posted by 32krazy!
beaner when you get yours installed would you check something for me?
when the fan switch is on the first dot it doesnt seem to heat my car at a stop. when moving it is fine and the 1 position will run me out of the cab! check yours and let me know if the first dot runs when you are stopped
thanx!
Have that same issue, I thought that was just how it was built. once you pass the fan picture the fan turns on but the dot before that just seems to open the vent. I find myself switching between the 1 until it is too hot and then the first dot to just maintain the temp. (using the xfire controls though, not one from another MB)
EDIT:: Also I prefer the xfire dial style, would it just be to hard to pull out the dials and ***** and paint? or did you switch the entire unit just for ease?
