Re: Bypassed Factory Fuel Regulator
I have added a link for pics to my first post. Yes woody I did use Hi Pressure fuel line I did not want to try to go into orbit by crossfire I would rather use the shuttle.
What was the highest AFR you were at before? 15 to 15.5
What psi of fuel pressure took it down to 13? last night I did not have the return line hooked up yet so the pressure was messed up I will give all the data as to what pressure does what when I finally get to the track.
What fuel pump are you running? Factory pump. It hit 130psi with the return line blocked off.
What did it to to your overall AFR in the low and midrange, surely it was richened as well? My low end AFR did richen some. My intent is once I get the top end where I want it I will send a bunch of data logs to Jerry and send them my computer and have them tweek it for me.
