Originally Posted by 94Bravada
I used a thing that plugs into where a fuse goes and then has a hot wire that comes out of it. They are only like 5 dollors at auto zone it's nice because you don't have to cut into any factory wiring also when u turn off your lights and shut your door your underbody lights come on for about a min
Fantastic now I'm getting somewhere.
Do you know what this is called and where does it connects at the fuse box. Do you connect where the fog light fuse goes? Is this like a fuse with another wire coming out for another hookup? Does this replace a fuse? Is the fuse box under hood and do you know what number fuse it goes in? Sounds great!
I found the connection pieces called "add a circuit" Now where to install to in the fuse box if you know. Ron
