Originally Posted by Xray
Okay I hooked up the fuel pump directly to the new regulator and ran a return line back to the fac return going to the tank. The only line still hooked up to the fact filter is the atmospheric line which is unused. the reason I was getting 130 psi and could not adjust it any lower than 80 is because I did not have a return line hooked up I had the return sealed which meant the regulator had no way to bleed off excess pressure. I am not sure what you are asking about the fuel rail I used the factory supply line and just inserted the new filter and reg in it.
Bulldogger I agree with what you are saying about more volume my question is how do you get more volume with out 1 of 2 things increased pressure or larger diameter fuel lines. I know for a good while now you have been a proponent of the sl55 fuel pump. What kind of AFR's are you running with it. My solution is not cheaper and def takes longer but I just could not figure out how a different pump going thru the same regulator and lines could solve the problem. Please Explain how it works.
Same way a boat prop works by changing the pitch on the impellar. The pressure in the line is only a factor if the pump you are using is maxing out the lines capability. Both the SRT6 and SL55 pumps have the same sized inlet and outlet. The SL55 pump is slightly longer and moves more LPH. Think of you garden house 1/2 open compared to full open, same size line but your moving more volume. Everyone assumes the fuel rail size is too small and maxed out, why???
