Originally Posted by Xray
Okay I hooked up the fuel pump directly to the new regulator and ran a return line back to the fac return going to the tank. The only line still hooked up to the fact filter is the atmospheric line which is unused. the reason I was getting 130 psi and could not adjust it any lower than 80 is because I did not have a return line hooked up I had the return sealed which meant the regulator had no way to bleed off excess pressure. I am not sure what you are asking about the fuel rail I used the factory supply line and just inserted the new filter and reg in it.
Sorry for the confusion. Can you post a pic?
Im trying to figure out where your new filter and regulator is located, before or after the fuel rail...
edit: nm about the pic i dont know how i missed the link, maybe you posted it after the fact.
