Old Jan 10, 2010 | 06:57 PM
Bulldogger's Avatar
Bulldogger
Default Re: Bypassed Factory Fuel Regulator
Originally Posted by Xray
82 psi max afr 13.2 Much better than afr's in the fifteens
The problem with increasing the pressure is the seals where the injectors attatach to the rails plus when you approach redline fuel rail pressure drops now you lift off and you are slamming the system with more then 82 psi. Pressure is going to cause something to pop off or start leaking.
