Old Jan 11, 2010 | 02:26 PM
  #57 (permalink)
Darticus's Avatar
Darticus
Default Re: Underbody Kit + Interior Lighting
Originally Posted by 94Bravada
Threre is a spot for the front and the sides but the back you have to make a bracket to drop it down below the exhaust. I screwed them on and then zipped tied them twice in the middle. I put the contorl box in the glove box little did I know the kit came with a control box you can mount outside the car untill after i installed mine. I got my kit off a friend that had them on a show truck for years. He later on found the box they came in and the other control box was in it.
When you say "I screwed them on" did you drill to put screws in? I'm trying not to drill. I guess you also made brackets for the back to get below the exhaust. I could leave the rear light off maybe.
Ledglow says their control box is not really for in the hood mounting but if you keep it dry its ok. I'm gonna put it in a sealed container in the hood area and I only drive in nice weather so it should be ok. Now if I could fit my fat body under the car I could try to see how to mount them. I could use a pic from under the car to see the layout as the car is in storage for the bad weather months. I can take it out but tooo cold to work in the garage now. Maybe I can get it on a lift when it warms up. Did you do your while on a lift? Ron
