Originally Posted by H82BL8
I mounted it with fourteen #10 3/4 zinc coated bolts. All of the holes are pretty far down, don't think it should be any problem if removed. I'm thinking of using some 3M tape also if I get it painted. Might also use some metal sandwich trim clips for some extra support in a couple spots. All in all its pretty damn solid, but I'm still going to be cautious with curbs and large speed bumps.
I'm assuming you drilled little pilot holes in the 7 tabs on either side, then used those as a guide to drill into the underside of the bumper cover, ultimately securing them with the #10 bolts? Is that enough to keep the center section nice and secure, or did you 3M tape the two center mounts?
Any other tips/pointers/suggestions you can offer on the install? I really think I'm going to pick one of these up, and leaving it black will perfectly match my black rear diffusers.
