Old Jan 15, 2010 | 07:02 PM
onehundred80
Default Re: nav went south toward Obama
Originally Posted by nox1s
I don't have a nav unit so I can't test anything but from what I recall..you may have to 'calibrate' it..
This is done by inserting DISC #1 (East?) and then driving around (up to 50-100 miles???).. it should auto-calibrate...
I think that you would insert the disk that is applicable to your area.
After leaving the system on and it has located enough satellite signals and shows "GPS OK" in the top right hand corner of the screen, it will tell you to load the CD, finish all the settings and as you drive it will figure itself out.
You know you are in trouble when the nav unit asks you for directions.
