Old Jan 18, 2010 | 03:42 PM
distantpulse's Avatar
distantpulse
Default Re: Simple MPH Question when DragRacing
Originally Posted by cruzinquick
The almighty torque is what most true bracket cars are setup with. I run against cars hitting low 12's all the time and barely trapping 102-104 mph. A true bracket car hitting 117 mph is a near 10 second car due to gearing, and those 60's are out of sight.
Who the hell sets their car up to run 10's at 117?? There is no way man. Not even bracket cars.....That is a little exaggerated. If you were running 10's at 117 flat out, your car is really f'ed up in the gearing of it in either the trans, rear or both! You would probably blow your motor too as it would be screaming at the top end. A 117 trap is right about an 11.40 player on a properly setup car, maybe a litte faster or a little slower depending on how it gets out of the hole. Now granted, I have seen the opposite on a 12.0 footbrake bracket car purposely setup to run 121 traps. Now that is cool!!
