Old Jan 19, 2010 | 03:38 PM
Xray's Avatar
Xray
Default Re: XRAY's new grille
Call them up and make sure they do not forget your springs for the upper grill. Also bust there chops to make sure they include a template for the lower grills. You will have to drill 2 small holes on each side of the divider in the lower portion of the bumper. If they cannot get you a template what I did was put a little grease on the end of the 2 mounting tabs. Lined the grill with the front edge of bumper and slid over till it made contact. I then drilled the holes. Do not try to slide the grills all the way back into the bummper they are 2 tall and even if you force them back the outside edges will stick out past the edge and loo like crap. Good luck if you have any questions just PM me with your number and I will call you.
