Old Jan 20, 2010 | 07:06 PM
green-ghost's Avatar
green-ghost
Default Re: Changing the Fuel Filter - 2004 Coupe
Originally Posted by chevyboyac
I could scan the pages from the manual and show u the steps but this site is actin weird with addin pics....but search you might be able to find the actual manual on here if you find a 05-07 manual its purdy much the same. The filter is in front of the pass. rear tire above a plastic cover take the 4 screws off and you will see it next to the fuel pump. Its really easy to change, just make sure to pull the fuel pump fuse out and start the car that will get rid of the pressure thats in the line and you won't leak fuel everywhere.
So its accessed in the wheel well or through the trunk? Also, is there a set procedure once its changed out concerning the whole fuse removal and fuel pressure procedure. Lastly, how do you guys know it needs changing, is it based on the milage or is the filter somehow visible to determine if its neccessary?
