Originally Posted by hcarter
You might want to turn on the lights ,walk around the car and see if one of the running lights are out also turn on the signal lights ,make sure all are working ......
Good hunting also notice you have HIDS check the wiring you may need resistors or have a ballast acting up...
I had a bad ballast (foglight) and it gave the same symptom.
