Old Jan 21, 2010 | 10:25 AM
onehundred80
Default Re: Engine Dies When Temperature Around Freezing
While these guys are giving good advice, I like Deb Walker's advice better: "If your battery is original, and your car is a 2004 or 5, you need a new battery. They tend to die without warning".
I ended up having my company's Dodge Durango refuse to run one day, $85 tow bill and 1/2 hour at the shop ($50 more) and all it was, was a bad battery! (It would crank, but not start. Acted like it was out of gas). That taught me a lesson:
I changed my Roadster's OEM battery this fall before venturing out to the Dragon. $90 well spent at O'Reilly's.
Even if the battery IS NOT your problem, it is still going to BE a problem. Get rid of it.
True enough pizzaguy, I got rid of my '04 battery last spring while it still worked fine. I will never let myself be caught with a weak battery.
The cost as pizzaguy says will often cover the cost of the battery.
Those Vartas do seem pretty long lived though.
