Old Jan 28, 2010 | 05:38 PM
rcompart's Avatar
rcompart
Default Re: Throttle Body Voltage Output
Originally Posted by kolevski
Does anyone know which wire is the "voltage output lead"? I unclipped the wire from the throttle body and theres about 4 wires I think, just not sure which one is the voltage output wire. Thanks guys
What are you looking to do? there are two wires that drive the motor in the TB. one is black, the other is purple. Purple is brought high with a PWM signal to open it, and vice versa when it closes it. If you're trying to add a dashdaq or ZT-2, you want to grab the yellow TPS wire.
