Re: XRAY's new grille
Glad they're working out.
A little tip for folks trying to line up a part to where you want a hole to go:
1) Put tape on the part where the hole is to be drilled (keeps the area clean and helps prevent the part from sliding around in Step #3)
2) Put some modeling clay (the clay used in cleaning the paint works great) "about" where you think the part will line up for the hole
3) Line up the part you want to attach and carefully push the part against the clay and then pull away--you'll leave a mark where you want the hole
4) Use a drill punch to mark the center of where you're going to drill
5) Drill the hole
6) Voila you're done
