Originally Posted by Darticus
Oil filter 7078 from NAPA is this the correct oil filter? Found 0W 40 mobil oil in Walmart today. I thought they stopped making it. Is there a special way to put the filter in? Do the seals go in a certain way? Should I buy the oil filter somewhere else other than NAPA? Thanks Ron
make sure o-rings are correctly place, look at old filter, and make sure the new filter is seated properly...good luck...you will do fine...easiest oil change I have ever done...I like the top sider...
