Old Jan 31, 2010 | 02:45 PM
oledoc2u
Default Re: NW Dual or C3 pulley
OK, this is why this forum can be interesting. I don't agree at all and here is why...when I added a single cai, my times dropped from low 13's to mid to high 12's, added the code 3 pulley, times dropped to mid 12's, added a tune, times dropped to low 12's, absolutely not one cooling mod. There are old fashion ways to cool, just a few bags of ice on the sc area between runs. The cooling mods are grt, and they work, but as stated, they add 0 HP...You need to start by learning which direction you want to build HP< on who you believe has the right path by looking on here, and reading, learning the times everyone is running with their particular mods...then start down that path...I have added the dual cai, and dropped another 2/10's...still 0 cooling mods...I am separating the system on the new car build...I will do the exact same mods to the coupe, but will add meth, and separate the cooling system....spend your money wisely, go for HP 1st, then fight the heat soak later....just my .02....
