Old Feb 2, 2010 | 10:05 PM
patpur's Avatar
patpur
Senior Member/Moderator
Default Re: Dealer work done - Whiskey Tango Foxtrot!!
Try the reset that is detailed in the owners manual ESP/BAS reset. if that doesn't do it have the battery checked. A low tire will also set off the light so I'm told. If none of those work it could be the "steering angle sensor" which went bad and did basically the same thing in our mercedes except there is no spoiler. I've also had this happen in the Crossfire where the reset worked.
