Originally Posted by BlazeRedXfire
I took my Crossfire into the dealership this morning to have the dreaded O-ring on the valve for the transmission replaced. Everything seems to be running fine. In and out in under 2 hours. I drive just over 20 miles and suddenly the spoiler deploys and wont go back down, the Check Engine light along with the ABS, ESP and another notification light all come on. What the crap did the dealer do to my beloved car!??!
PLEASE let me know what comes of this. I have had the same issue, minus the CEL. I am having the BAS/ESP and ABS lights lit constantly and the spoiler stays deployed and the light on the spoiler button blinks steadily. I have tried both resets (disconnecting negative terminal and replace then do the full left to full right so it can 'learn' the stops) and nothing. I am going to pull apart the sensors in the wheels to see if any moisture got in there, based on advice from a trusted source with the same problem. If that does not work, I will be checking the steering angle sensor as Pat suggested. Keep me posted and I will do the same.
Johyn
