Thread: Loss of Power
Old Feb 4, 2010 | 12:05 PM
tighed1's Avatar
tighed1
Default Re: Loss of Power
Don't be so quick to jump on the IC pump bandwagon.
Others have found problems with the air temp sensor to cause the same symptoms.
I had
I had the same problem I was told that the IC pump was going bad and to get a Johnson Pump to cure my problem. So I spent $170 got the pump, installed it and...you guessed it, same problem.
Woody told me to move the heat exchanger higher up into the air flow (free mod). I did that and have been problem free ever since. That includes while running stacked pulleys.
Might be worth a try. Worked for me!
Of course now I'm running the Super Cooler on both cars. Still no overtemp problems!
