Old Feb 5, 2010 | 01:53 AM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: NW Dual or C3 pulley
Originally Posted by bmorgan
Doc, I generally agree with Steve(32Krazy!), but I am with you on this one. I have yet to do any cooling mods. Once I get the raw HP and torque I want, then I can worry about cooling mods. You are right, A 10lb bag of ice sitting on top of the SC will do wonders for heat soak. I have not done complete homework on this yet, but as of right now, I think my first cooling mod will be meth. I think I will get more from meth as a cooling mod than I will with separating the cooling system. If i am wrong on this, please let me know. I am not far away from making this decision, and want to do it right the first time. Thanks
Good advice if drag racing is the goal and you have time to park and ice down. Get the power first - then play with cooling.
Cheapest cooling mod for the drag strip is a potentiometer. Disconnect the plug from the IAT sensor and plug in a potentiometer. Tell the ECU your IAT's are stable @ 70*. This will prevent the ECU from pulling timing (regardless of the real temp) just be careful.
It won't matter how much meth you spray if you inject it after the IAT sensor. Once the ECU senses hot temps - it's going to protect the engine and pull timing. That's its job.
