Old Feb 5, 2010 | 08:48 AM
32krazy!'s Avatar
32krazy!
Default Re: NW Dual or C3 pulley
Originally Posted by MikeR
Doc, I have my cooling system separated. Mezier surge tank and using the factory tank for the IC with a CM30 and LET HE. I tried using ice at the track between runs and it does help. But I can sit for 30 mins and get cooled waaaay down. Enough so that my next run is good but if I hot lap, the following run (with the engine at temp) is better.
What I need is to get my IAT down significantly with the engine at good operating temp. Either a big aux tank for the IC with COLD water or some meth seem like viable options.....
mike if you look at some of brianbraves threads you will see that he tried the bigger tank and what the result was longer times between heat soak but the coolant eventually heats up to temp no matter how much is used. it simply cant be cooled down quick enough to justify a 5 gal tank and the weight associated with it.
now the meth thats a different story!!
