Re: I need some *Help* if you could!
I've had a similar problem with a Honda and an Audi. Two simple things to check are: engine cover, is it seated properly against the throttle body? Also check to make sure your spark plugs are tight.Sometimes they get loose and throw codes similar to a vacuum leak. Good luck.
