Originally Posted by srtcoupe
Do you have an extended warranty?
The shaft in the supercharger should not be turning because you are not at the required rpm to engage the clutch on the SC and the SC will not engage when in park. Based on that and your description of the noise being to the front I would look at your clutch and pulley. Did you put an aftermarket pulley on the SC? Some of the earlier aftermarket pulleys were apt to come apart.
With what little there is to go on, I don't think you have a supercharger failure, I would look toward the SC clutch and pulley.
I work in the city, if you are close by I could look at it after work.
I would have to agree...something engaging clutch, or a pulley failure...doubt it is the s/c....
